Stochastic neural field equations: A rigorous footing
We extend the theory of neural fields which has been developed in a deterministic framework by considering the influence spatio-temporal noise. The outstanding problem that we here address is the development of a theory that gives rigorous meaning to stochastic neural field equations, and conditions ensuring that they are well-posed. Previous investigations in the field of computational and mathematical neuroscience have been numerical for the most part. Such questions have been considered for a long time in the theory of stochastic partial differential equations, where at least two different approaches have been developed, each having its advantages and disadvantages. It turns out that both approaches have also been used in computational and mathematical neuroscience, but with much less emphasis on the underlying theory. We present a review of two existing theories and show how they can be used to put the theory of stochastic neural fields on a rigorous footing. We also provide general conditions on the parameters of the stochastic neural field equations under which we guarantee that these equations are well-posed. In so doing we relate each approach to previous work in computational and mathematical neuroscience. We hope this will provide a reference that will pave the way for future studies (both theoretical and applied) of these equations, where basic questions of existence and uniqueness will no longer be a cause for concern.
