Service-Oriented Programming with Jolie
The wide adoption of service-oriented computing has led to a heterogeneous scenario formed by different technologies and specifications. Examples can be found both at the design level -the frameworks for defining services and those for defining their coordination feature fundamentally different primitives- and at the implementation level -different communication technologies are used depending on the context. In this paper we present Jolie, a fully-fledged service-oriented programming language. Jolie addresses the aforementioned heterogeneity in two ways. On the one hand, it combines computation and composition primitives in an intuitive and concise syntax. On the other hand, the behaviour and deployment of a Jolie program are orthogonal: they can be independently defined and recombined as long as they have compatible typing.
