Logic and computation in a lambda calculus with intersection and union types - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present an explicitly typed lambda calculus "à la Church" based on the union and intersection types discipline; this system is the counterpart of the standard type assignment calculus "à la Curry." Our typed calculus enjoys Subject Reduction and confluence, and typed terms are strongly normal- izing when the universal type is omitted. Moreover both type checking and type reconstruction are decidable. In contrast to other typed calculi, a system with union types will fail to be "coherent" in the sense of Tannen, Coquand, Gunter, and Scedrov: different proofs of the same typing judgment will not necessarily have the same meaning. In response, we introduce a decidable notion of equality on type-assignment derivations inspired by the equational theory of bicartesian-closed categories.
lpar.pdf (152.29 Ko) Télécharger le fichier
hal-00909535 , version 1 (26-11-2013)
Daniel J. Dougherty, Luigi Liquori. Logic and computation in a lambda calculus with intersection and union types. 16th International Conference on Logic for Programming, Artificial Intelligence, and Reasoning, LPAR-16, Dakar, Senegal, April 25–May 1, 2010, Revised Selected Papers, Apr 2010, Dakar, Senegal. pp.173-191, ⟨10.1007/978-3-642-17511-4_11⟩. ⟨hal-00909535⟩
Collections
INRIA INRIA2
103 Consultations
125 Téléchargements
