Teleprogramming the motions of a planetary robot using physical models and dynamic simulation tools - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1992
Stéphane Jimenez
  • Fonction : Auteur
Annie Luciani
  • Fonction : Auteur
  • PersonId : 829772
The contribution presented in the paper is a motion generator whose purpose is to instanciate a nominal motion plan into a more complete motion plan referred as the executive model. The nominal motion plan is expressed in terms of a channel to follow and a set of intermediate subgoals to reach. The nominal motion plan is expressed in terms of a channel to follow and a set of intermediate subgoals to reach. The basic idea is to make use of appropriate physical models and dynamic simulation tools for predicting the behavior of the vehicle.
Fichier non déposé
hal-00910548 , version 1 (28-12-2013)
  • HAL Id : hal-00910548 , version 1
Stéphane Jimenez, Annie Luciani, Christian Laugier. Teleprogramming the motions of a planetary robot using physical models and dynamic simulation tools. IROS'92, 1992, Raleigh NC, United States. pp.1383-1390. ⟨hal-00910548⟩
Collections
UGA ACROE-ICA
90 Consultations
0 Téléchargements
