Simulating Physical Interactions between an Articulated Mobile Vehicle and a Terrain - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1991
This paper deals with the problem of simulating the notions of a complex land vehicle moving in a natural environment. The contribution presented here is a motion generator which predicts the dynamic behaviour of the vehicle when executing a given nominal motion plan. This plan is expressed in terms of a channel to follow and of a set of intermediate subgoals to reach. Solving this motion generation problem requires to explicitly reason about the geometric and the physical aspects of the movements that the vehicle has to execute. In our approach, this is done using two basic constructions derived from the concept of physical model : the 'generalized obstades" are used for physically guiding the movements of the vehicle using an explicit model of the vehicle/terrain interactions, and the "physical targets' are used to map the strategic information onto our physical representation of the world and to introduce the force feedback gestural control.
JLL91_Conf_ORIA.pdf (759.57 Ko) Télécharger le fichier
hal-00910550 , version 1 (11-03-2014)
  • HAL Id : hal-00910550 , version 1
Stéphane Jimenez, Annie Luciani, Christian Laugier. Simulating Physical Interactions between an Articulated Mobile Vehicle and a Terrain. ORIA'91, 1991, Marseille, France. pp.11. ⟨hal-00910550⟩
Collections
UGA CNRS ACROE-ICA
111 Consultations
130 Téléchargements
