A class of multivariate copulas based on products of bivariate copulas - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Preprints, Working Papers, ... Year : 2014
Copulas are a useful tool to model multivariate distributions. While there exist various families of bivariate copulas, much fewer has been done when the dimension is higher. In this paper we propose a class of multivariate copulas based on products of transformed bivariate copulas. No constraints on the parameters refrain the applicability of the proposed class. Furthermore the analytical forms of the copulas within this class allow to naturally associate a graphical structure which helps to visualize the dependencies and to compute the likelihood efficiently even in high dimension.
paper-2.pdf (382.34 Ko) Télécharger le fichier
Origin : Publisher files allowed on an open archive
Dates and versions
hal-00910775 , version 1 (29-11-2013)
hal-00910775 , version 2 (07-07-2014)
hal-00910775 , version 3 (08-07-2014)
hal-00910775 , version 4 (21-05-2015)
Identifiers
  • HAL Id : hal-00910775 , version 2
Cite
Gildas Mazo, Stéphane Girard, Florence Forbes. A class of multivariate copulas based on products of bivariate copulas. 2014. ⟨hal-00910775v2⟩
701 View
1475 Download
Share
