First Flight Tests for a Quadrotor UAV with Tilting Propellers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this work we present a novel concept of a quadrotor UAV with tilting propellers. Standard quadrotors are limited in their mobility because of their intrinsic underac- tuation (only 4 independent control inputs vs. their 6-dof pose in space). The quadrotor prototype discussed in this paper, on the other hand, has the ability to also control the orientation of its 4 propellers, thus making it possible to overcome the aforementioned underactuation and behave as a fully-actuated flying vehicle. We first illustrate the hardware/software specifi- cations of our recently developed prototype, and then report the experimental results of some preliminary, but promising, flight tests which show the capabilities of this new UAV concept.
2013_icra_ryll.pdf (1.79 Mo) Télécharger le fichier
hal-00910823 , version 1 (28-11-2013)
Markus Ryll, Heinrich H Bülthoff, Paolo Robuffo Giordano. First Flight Tests for a Quadrotor UAV with Tilting Propellers. IEEE Int. Conf. on Robotics and Automation, ICRA 2013, May 2013, Karlsruhe, Germany. pp.295-302, ⟨10.1109/ICRA.2013.6630591⟩. ⟨hal-00910823⟩
298 Consultations
642 Téléchargements
