Task-Based FMM for Multicore Architectures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Scientific Computing Année : 2014
Fast Multipole Methods (FMM) are a fundamental operation for the simulation of many physical problems. The high performance design of such methods usually requires to carefully tune the algorithm for both the targeted physics and hardware. In this paper, we propose a new approach that achieves high performance across architectures. Our method consists of expressing the FMM algorithm as a task flow and employing a state- of-the-art runtime system, StarPU, to process the tasks on the different computing units. We carefully design the task flow, the mathematical operators, their implementations as well as scheduling schemes. Potentials and forces on 200 million particles are computed in 42.3 seconds on a homogeneous 160 cores SGI Altix UV 100 and good scalability is shown.
sisc-cpu.pdf (2.39 Mo) Télécharger le fichier
hal-00911856 , version 1 (30-11-2013)
Emmanuel Agullo, Bérenger Bramas, Olivier Coulaud, Eric Darve, Matthias Messner, et al.. Task-Based FMM for Multicore Architectures. SIAM Journal on Scientific Computing, 2014, 36 (1), pp.66-93. ⟨10.1137/130915662⟩. ⟨hal-00911856⟩
378 Consultations
462 Téléchargements
