Periodic external input tunes the stability of delayed nonlinear systems: from the slaving principle to center manifolds
The work illustrates a recent analysis technique that demon- strates that external periodic input affects the stability of the time- averaged nonlinear dynamics of a delayed system. At first, the article introduces the fundamental elements of delayed differential equations and then applies these to a nonlinear delayed problem close to a trans- critical bifurcation. We observe a shift of stability in the system induced by the fast periodic driving.
Modélisation et simulation
