A Framework for Improving Uniformity of Parameterizations of Curves - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Journal Articles Science China Information Sciences Year : 2013
Hoon Hong
  • Function : Author
  • PersonId : 935617
Dongming Wang
  • Function : Author
  • PersonId : 835371
Jing Yang
  • Function : Author
We define quasi-speed as a generalization of linear speed and angular speed for parameterizations of curves and use the uniformity of quasi-speed to measure the quality of the parameterizations. With such conceptual setting, a general framework is developed for studying uniformity behaviors under reparameterization via proper parameter transformation and for computing reparameterizations with improved uniformity of quasispeed by means of optimal single-piece, C 0 piecewise, and C 1 piecewise Möbius transformations. Algorithms are described for uniformity-improved reparameterization using different Möbius transformations with different optimization techniques. Examples are presented to illustrate the concepts, the framework, and the algorithms. Experimental results are provided to validate the framework and to show the efficiency of the algorithms.
Dates and versions
hal-00913394 , version 1 (03-12-2013)
Identifiers
Cite
Hoon Hong, Dongming Wang, Jing Yang. A Framework for Improving Uniformity of Parameterizations of Curves. Science China Information Sciences, 2013, 56 (10), pp.108101:1-108101:22. ⟨10.1007/s11432-013-4924-4⟩. ⟨hal-00913394⟩
130 View
0 Download
Share
