Ambivalent Types for Principal Type Inference with GADTs (extended version) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
GADTs, short for Generalized Algebraic DataTypes, which allow constructors of algebraic datatypes to be non-surjective, have many useful applications. However, pattern matching on GADTsintroduces local type equality assumptions, which are a source of ambiguities that may destroy principal types---and must be resolved by type annotations. We introduce ambivalent types to tighten the definition of ambiguities and better confine them, so that type inference has principal types, remains monotonic, and requires fewer type annotations.
Garrigue-Remy_gadts_long2013.pdf (292.93 Ko) Télécharger le fichier
hal-00914493 , version 1 (06-12-2013)
hal-00914493 , version 2 (10-12-2013)
  • HAL Id : hal-00914493 , version 2
Jacques Garrigue, Didier Rémy. Ambivalent Types for Principal Type Inference with GADTs (extended version). 2013. ⟨hal-00914493v2⟩
Collections
INRIA INRIA2
135 Consultations
179 Téléchargements
