CALCioM: Mitigating I/O Interference in HPC Systems through Cross-Application Coordination - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Unmatched computation and storage performance in new HPC systems have led to a plethora of I/O optimizations ranging from application-side collective I/O to network and disk-level request scheduling on the file system side. As we deal with ever larger machines, the interferences produced by multiple applications accessing a shared parallel file system in a concurrent manner become a major problem. These interferences often break single-application I/O optimizations, dramatically degrading application I/O performance and, as a result, lowering machine wide efficiency. This paper focuses on CALCioM, a framework that aims to mitigate I/O interference through the dynamic selection of appropriate scheduling policies. CALCioM allows several applications running on a supercomputer to communicate and coordinate their I/O strategy in order to avoid interfering with one another. In this work, we examine four I/O strategies that can be accommodated in this framework: serializing, interrupting, interfering and coordinating. Experiments on Argonne's BG/P Surveyor machine and on several clusters of the French Grid'5000 show how CALCioM can be used to efficiently and transparently improve the scheduling strategy between two otherwise interfering applications, given specified metrics of machine wide efficiency.
CALCioM.pdf (368.06 Ko) Télécharger le fichier
hal-00916091 , version 1 (09-04-2014)
  • HAL Id : hal-00916091 , version 1
Matthieu Dorier, Gabriel Antoniu, Robert Ross, Dries Kimpe, Shadi Ibrahim. CALCioM: Mitigating I/O Interference in HPC Systems through Cross-Application Coordination. IPDPS - International Parallel and Distributed Processing Symposium, May 2014, Phoenix, United States. ⟨hal-00916091⟩
1033 Consultations
590 Téléchargements
