Coupling the SAEM algorithm and the extended Kalman filter for maximum likelihood estimation in mixed-effects diffusion models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Statistics and Its Interface Année : 2013
We consider some general mixed-effects diffusion models, in which the observations are made at discrete time points and include measurement errors. In these models, the observed likelihood is generally not explicit, making maximum likelihood estimation of the parameters particularly complex. We propose a specific inference methodology for these models. In particular, we combine the SAEM algorithm with the extended Kalman filter to estimate the population parameters. We also provide some tools for estimating the individual parameters, for recovering the individual underlying diffusion trajectories and for evaluating the model. The methods are evaluated on simulations and applied to a pharmacokinetics example.
SII-6-4-a10-Delattre.pdf (473.51 Ko) Télécharger le fichier
hal-00916803 , version 1 (12-12-2013)
  • HAL Id : hal-00916803 , version 1
  • PRODINRA : 395975
  • WOS : 000330487100010
Maud Delattre, Marc Lavielle. Coupling the SAEM algorithm and the extended Kalman filter for maximum likelihood estimation in mixed-effects diffusion models. Statistics and Its Interface, 2013, 6 (4), pp.519--532. ⟨hal-00916803⟩
431 Consultations
695 Téléchargements
