Markov-modulated stochastic recursive equations with applications to delay-tolerant networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Performance Evaluation Année : 2013
We investigate a class of Markov-modulated stochastic recursive equations. This class includes multi-type branching processes with immigration as well as linear stochastic equations. Conditions are established for the existence of a stationary solution and expressions for the rst two moments of this solution are found. Furthermore, the transient characteristics of the stochastic recursion are investigated: we obtain the rst two moments of the transient solution as well. Finally, to illustrate our approach, the results are applied to the performance evaluation of packet forwarding in delay-tolerant mobile ad-hoc networks.
dieter.pdf (294.48 Ko) Télécharger le fichier
hal-00916920 , version 1 (10-12-2013)
Dieter Fiems, Eitan Altman. Markov-modulated stochastic recursive equations with applications to delay-tolerant networks. Performance Evaluation, 2013, 70 (11), pp.965-980. ⟨10.1016/j.peva.2013.06.001⟩. ⟨hal-00916920⟩
Collections
INRIA INRIA2
94 Consultations
159 Téléchargements
