Patch-based Segmentation of Brain Tissues - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We describe our submission to the Brain Tumor Segmentation Challenge (BraTS) at MICCAI 2013. This segmentation approach is based on similarities between multi-channel patches. After patches are extracted from several MR channels for a test case, similar patches are found in training images for which label maps are known. These labels maps are then combined to result in a segmentation map for the test case. The labelling is performed, in a leave-one-out scheme, for each case of a publicly available training set, which consists of 30 real cases (20 high-grade gliomas, 10 low-grade gliomas) and 50 synthetic cases (25 high-grade gliomas, 25 low-grade gliomas). Promising results are shown on the training set, and we believe this algorithm would perform favourably well in comparison to the state of the art on a testing set.
Cordier-MICCAI-2013-Challenge.pdf (866.4 Ko) Télécharger le fichier
hal-00917084 , version 1 (16-12-2013)
  • HAL Id : hal-00917084 , version 1
Nicolas Cordier, Bjoern Menze, Hervé Delingette, Nicholas Ayache. Patch-based Segmentation of Brain Tissues. MICCAI Challenge on Multimodal Brain Tumor Segmentation, Sep 2013, Nagoya, Japan. pp.6 - 17. ⟨hal-00917084⟩
Collections
INRIA INRIA2
702 Consultations
850 Téléchargements
