Reconstruction in the Labeled Stochastic Block Model
The labeled stochastic block model is a random graph model representing networks with community structure and interactions of multiple types. In its simplest form, it consists of two communities of approximately equal size, and the edges are drawn and labeled at random with probability depending on whether their two endpoints belong to the same community or not. It has been conjectured in [1] that this model exhibits a phase transition: reconstruction (i.e. identification of a partition positively correlated with the "true partition" into the underlying communities) would be feasible if and only if a model parameter exceeds a threshold. We prove one half of this conjecture, i.e., reconstruction is impossible when below the threshold. In the converse direction, we introduce a suitably weighted graph. We show that when above the threshold by a specific constant, reconstruction is achieved by (1) minimum bisection, and (2) a spectral method combined with removal of nodes of high degree.
