Explicit robustness margins for discrete-time linear systems with PWA control - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2013
The paper considers the class of discrete-time linear dynamics in closed loop with a piecewise affine control law defined over a bounded region of the state space X. Given a polytopic uncertainty on the nominal model of the system, the objective is to describe the largest subset of this parametric uncertainty for which the positive invariance of the set X is guaranteed with respect to the closed loop dynamics. This subset describes in fact a robust invariance margin which represents in general terms an important element in the study of the robust stability of any piecewise affine dynamics. It is shown that the necessary and sufficient conditions for set inclusion lead to convex formulations of the robustness margin. A series of remarks on the structure of the numerical problems are discussed and a numerical example is provided for illustration.
Domains
Automatic
No file
Dates and versions
hal-00917917 , version 1 (12-12-2013)
Identifiers
Cite
Sorin Olaru, Ngoc Anh Nguyen, Pedro Rodriguez-Ayerbe, George Bitsoris, Morten Hovd. Explicit robustness margins for discrete-time linear systems with PWA control. 17th International Conference on System Theory, Control and Computing (ICSTCC 2013) , Oct 2013, Sinaïa, Romania. pp.380-385, ⟨10.1109/ICSTCC.2013.6688989⟩. ⟨hal-00917917⟩
200 View
0 Download
Share
