Hector: Detecting resource-release omission faults in error-handling code for systems software
Omitting resource-release operations in systems error handling code can lead to memory leaks, crashes, and deadlocks. Finding omission faults is challenging due to the difficulty of reproducing system errors, the diversity of system resources, and the lack of appropriate abstractions in the C language. To address these issues, numerous approaches have been proposed that globally scan a code base for common resource-release operations. Such macroscopic approaches are notorious for their many false positives, while also leaving many faults undetected. We propose a novel microscopic approach to finding resource-release omission faults in systems software. Rather than generalizing from the entire source code, our approach focuses on the error-handling code of each function. Using our tool, Hector, we have found over 370 faults in six systems software projects, including Linux, with a 23% false positive rate. Some of these faults allow an unprivileged malicious user to crash the entire system.
Système d'exploitation [cs.OS]
