Analysis of the Jobs Resource Utilization on a Production System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Joseph Emeras
  • Fonction : Auteur
  • PersonId : 911806
Jean-Marc Vincent
Olivier Richard
In HPC community the System Utilization metric enables to determine if the resources of the cluster are efficiently used by the batch scheduler. This metric considers that all the allocated resources (memory, disk, processors, etc) are full-time utilized. To optimize the system performance, we have to consider the effective physical consumption by jobs regarding the resource allocations. This information gives an insight into whether the cluster resources are efficiently used by the jobs. In this work we propose an analysis of production clusters based on the jobs resource utilization. The principle is to collect simultaneously traces from the job scheduler (provided by logs) and jobs resource consumption. The latter has been realized by developing a job monitoring tool, whose impact on the system has been measured as lightweight (0.35% speed-down). The key point is to statistically analyze both traces to detect and explain underutilization of the resources. This could enable to detect abnormal behavior, bottlenecks in the cluster leading to a poor scalability, and justifying optimizations such as gang scheduling or best-effort scheduling. This method has been applied to two medium sized production clusters on a period of eight months.
emeras.pdf (1.09 Mo) Télécharger le fichier
hal-00918372 , version 1 (13-12-2013)
  • HAL Id : hal-00918372 , version 1
Joseph Emeras, Cristian Ruiz, Jean-Marc Vincent, Olivier Richard. Analysis of the Jobs Resource Utilization on a Production System. Job Scheduling Strategies for Parallel Processing, 2013, Boston, United States. ⟨hal-00918372⟩
258 Consultations
475 Téléchargements
