Comparison of free-streaming ELM formulae to a Vlasov simulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Nuclear Materials Année : 2013
The main drawbacks of the original free-streaming equations for edge localised mode transport in the scrape-off layer [W. Fundamenski, R.A. Pitts, Plasma Phys. Control Fusion 48 (2006) 109] are that the plasma potential is not accounted for and that only solutions for ion quantities are considered. In this work, the equations are modified and augmented in order to address these two issues. The new equations are benchmarked against (and justified by) a numerical simulation which solves the Vlasov equation in 1d1v. When the source function due to an edge localised mode is instantaneous, the modified free-streaming 'impulse response' equations agree closely with the Vlasov simulation results. When the source has a finite duration in time, the agreement worsens. However, in all cases the match is encouragingly good, thus justifying the applicability of the free-streaming approach.
freestream.pdf (318.15 Ko) Télécharger le fichier
hal-00918414 , version 1 (17-12-2013)
D. Moulton, W. Fundamenski, Giovanni Manfredi, Sever Adrian Hirstoaga, David Tskhakaya. Comparison of free-streaming ELM formulae to a Vlasov simulation. Journal of Nuclear Materials, 2013, Proceedings of the 20th International Conference on Plasma-Surface Interactions in Controlled Fusion Devices, 438, Supplement, pp.S633-S637. ⟨10.1016/j.jnucmat.2013.01.133⟩. ⟨hal-00918414⟩
476 Consultations
404 Téléchargements
