The Best-partitions Problem: How to Build Meaningful Aggregations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The design and the debugging of large distributed AI systems require abstraction tools to build tractable macroscopic descriptions. Data aggregation can provide such abstractions by partitioning the systems dimensions into aggregated pieces of information. This process leads to information losses, so the partitions should be chosen with the greatest caution, but in an acceptable computational time. While the number of possible partitions grows exponentially with the size of the system, we propose an algorithm that exploits exogenous constraints regarding the system semantics to find best partitions in a linear or polynomial time. We detail two constrained sets of partitions that are respectively applied to temporal and spatial aggregation of an agent-based model of international relations. The algorithm succeeds in providing meaningful high-level abstractions for the system analysis.
Fichier non déposé
hal-00918433 , version 1 (13-12-2013)
Robin Lamarche-Perrin, Yves Demazeau, Jean-Marc Vincent. The Best-partitions Problem: How to Build Meaningful Aggregations. IAT 2013 - IEEE/WIC/ACM International Conference on Intelligent Agent Technology, Nov 2013, Atlanta, GA, United States. pp.399-404, ⟨10.1109/WI-IAT.2013.138⟩. ⟨hal-00918433⟩
120 Consultations
0 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
