Efficient Data-Intensive Event-Driven Interaction in SOA - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents a middleware that enables the efficient delivery of events carrying large attachments. We transpar- ently decouple event-description from event-data, in order to avoid useless data-transfers and modifications to endpoints business logic. Our solution relieves the event-delivery sys- tem of large data transfers, by enabling direct, but trans- parent, publisher to subscriber data-exchange. The experi- ments show that we can reduce the average event delivery time by half, compared to a standard approach requiring the full mediation of the event-delivery system.
SAC13.pdf (202.2 Ko) Télécharger le fichier
hal-00918637 , version 1 (17-12-2013)
Quirino Zagarese, Gerardo Canfora, Eugenio Zimeo, Iyad Alshabani, Laurent Pellegrino, et al.. Efficient Data-Intensive Event-Driven Interaction in SOA. SAC '13, the 28th Annual ACM Symposium on Applied Computing, Mar 2013, Coimbra, Portugal. pp.1907-1912, ⟨10.1145/2480362.2480715⟩. ⟨hal-00918637⟩
245 Consultations
202 Téléchargements
