Admission control to an M/M/1 queue with partial information - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We consider both a cooperative as well as non-cooperative admis- sion into an M/M/1 queue. The only information available is a signal that sais whether the queue size is smaller than some L or not. We rst compute the globally optimal and the Nash equilibrium stationary policy as a function of L. We compare the performance to that of full information and of no information on the queue size. We identify the L that optimizes the equilibrium performance.
mm1.pdf (145.14 Ko) Télécharger le fichier
hal-00918808 , version 1 (15-12-2013)
Eitan Altman, Tania Jimenez. Admission control to an M/M/1 queue with partial information. ASMTA - 20th International Conference on Analytical & Stochastic Modelling Techniques & Applications, Jul 2013, Ghent, Belgium. pp.12-21, ⟨10.1007/978-3-642-39408-9_2⟩. ⟨hal-00918808⟩
230 Consultations
366 Téléchargements
