A stochastic HJB equation for optimal control of forward-backward SDEs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
Agnès Sulem
  • Fonction : Auteur
  • PersonId : 865285
Tusheng Zhang
  • Fonction : Auteur
  • PersonId : 828630
We study optimal stochastic control problems of general coupled systems of forward- backward stochastic di erential equations with jumps. By means of the It^o-Ventzell formula the system is transformed to a controlled backward stochastic partial di eren- tial equation (BSPDE) with jumps. Using a comparison principle for such BSPDEs we obtain a general stochastic Hamilton-Jacobi- Bellman (HJB) equation for such control problems. In the classical Markovian case with optimal control of jump di usions, the equation reduces to the classical HJB equation. The results are applied to study risk minimization in nancial markets.
HJB.pdf (129.67 Ko) Télécharger le fichier
hal-00919141 , version 1 (16-12-2013)
  • HAL Id : hal-00919141 , version 1
Bernt Øksendal, Agnès Sulem, Tusheng Zhang. A stochastic HJB equation for optimal control of forward-backward SDEs. 2013. ⟨hal-00919141⟩
285 Consultations
1145 Téléchargements
