Real numbers, chaos, and the principle of a bounded density of information
Two definitions of the notion of a chaotic transformation are compared: sensitivity to initial conditions and sensitivity to perturba- tions. Only the later is compatible with the idea that information has a nite density.
Logique en informatique [cs.LO]
