RiskRRT-Based Planning For Interception of Moving Objects in Complex Environments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents a new approach for the interception of moving objects using UGVs in large complex environments. The planning for interception is based on the Risk-RRT algorithm. Several modi cafitions have been made to the base algorithm to enhance its ability to move in uncertain environments. The planner is integrated with a navigation architecture. The full system is capable of parallel on-line planning and following of the path. It performs the interception and at the same time it avoids static and dynamic obstacles. Several tests, both in simulation and with real world robots, were carried out showing the effectiveness of the proposed system.
Fichier non déposé
hal-00920884 , version 1 (19-12-2013)
  • HAL Id : hal-00920884 , version 1
Mario Garzón, Efstathios P Fotiadis, Antonio Barrientos, Anne Spalanzani. RiskRRT-Based Planning For Interception of Moving Objects in Complex Environments. ROBOT2013: First Iberian Robotics Conference, 2013, Madrid, Spain. pp.489--503. ⟨hal-00920884⟩
154 Consultations
0 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
