A novel energy efficient broadcast leader election - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We introduce a new algorithm to achieve a distributed leader election in a broadcast channel that is more efficient than the classic Part-and-Try algorithm. The algorithm has the adavantage of having a reduced overhead $\log\log N$ rather than $\log N$. More importantly the algorithm has the a greatly reduced energy consumption since it requires $O(N^{1/k})$ burst transmissions instead of $O(N/k)$, per election, $k$ being a parameter depending on the physical properties of the medium of communication. The algorithm has interesting potential applications in wireless cognitive networking.
election2.pdf (378.32 Ko) Télécharger le fichier
hal-00921148 , version 1 (19-12-2013)
  • HAL Id : hal-00921148 , version 1
Philippe Jacquet, Dimitrios Milioris, Paul Mühlethaler. A novel energy efficient broadcast leader election. MASCOTS 2013 - 21st IEEE International Symposium on Modeling, Analysis and Simulation of Computer and Telecommunication Systems, Aug 2013, San Francisco, United States. ⟨hal-00921148⟩
249 Consultations
320 Téléchargements
