Adaptive control for optimizing microalgae production - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we propose a nonlinear adaptive controller for light-limited microalgae culture. This controller regulates the light absorption factor, defined by the ratio between the incident light and the light at the bottom of the reactor. Then, we propose a set-point for the light absorption factor which allows to optimize biomass productivity under constant illumination. Finally, we show by numerical simulation that the adaptive controller can be used to obtain near optimal productivity under day-night cycles.
cab-control_algae_v4.pdf (214.32 Ko) Télécharger le fichier
hal-00921486 , version 1 (20-12-2013)
  • HAL Id : hal-00921486 , version 1
  • PRODINRA : 281434
Francis Mairet, Rafael Munoz Tamayo, Olivier Bernard. Adaptive control for optimizing microalgae production. Computer Application in Biotechnology (CAB2013), Dec 2013, Mumbai, India. ⟨hal-00921486⟩
599 Consultations
387 Téléchargements
