Polynomial-degree-robust a posteriori estimates in a unified setting for conforming, nonconforming, discontinuous Galerkin, and mixed discretizations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
We present equilibrated flux a posteriori error estimates in a unified setting for conforming, nonconforming, discontinuous Galerkin, and mixed finite element discretizations of the two-dimensional Poisson problem. Relying on the equilibration by the mixed finite element solution of patchwise Neumann problems, the estimates are guaranteed, locally computable, locally efficient, and robust with respect to polynomial degree. Maximal local overestimation is guaranteed as well.
a_post_p_rob.pdf (337.53 Ko) Télécharger le fichier
hal-00921583 , version 1 (20-12-2013)
hal-00921583 , version 2 (30-07-2014)
  • HAL Id : hal-00921583 , version 1
Alexandre Ern, Martin Vohralík. Polynomial-degree-robust a posteriori estimates in a unified setting for conforming, nonconforming, discontinuous Galerkin, and mixed discretizations. 2013. ⟨hal-00921583v1⟩
Collections
ENPC CERMICS
377 Consultations
830 Téléchargements
