Generalizing precision and recall for evaluating ontology matching
We observe that the precision and recall measures are not able to discriminate between very bad and slightly out of target alignments. We propose to generalise these measures by determining the distance between the obtained alignment and the expected one. This generalisation is done so that precision and recall results are at least preserved. In addition, the measures keep some tolerance to errors, i.e., accounting for some correspondences that are close to the target instead of out of target.
