Time granularity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2005
Time granularity
A temporal situation can be described at different levels of abstraction depending on the accuracy required or the available knowledge. Time granularity can be defined as the resolution power of the temporal qualification of a statement. Providing a formalism with the concept of time granularity makes it possible to model time information with respect to differently grained temporal domains. This does not merely mean that one can use different time units - e.g., months and days - to represent time quantities in a unique flat temporal model, but it involves more difficult semantic issues related to the problem of assigning a proper meaning to the association of statements with the different temporal domains of a layered temporal model and of switching from one domain to a coarser/finer one. Such an ability of providing and relating temporal representations at different "grain levels" of the same reality is both an interesting research theme and a major requirement for many applications (e.g. agent communication or integration of layered specifications). After a presentation of the general properties required by a multi-granular temporal formalism, we discuss the various issues and approaches to time granularity proposed in the literature. We focus on the main existing formalisms for representing and reasoning about quantitative and qualitative time granularity: the general set-t
euzenat2005a.pdf (873.27 Ko) Télécharger le fichier
hal-00922282 , version 1 (25-12-2013)
  • HAL Id : hal-00922282 , version 1
Jérôme Euzenat, Angelo Montanari. Time granularity. Michael Fisher, Dov Gabbay, Lluis Vila. Handbook of temporal reasoning in artificial intelligence, Elsevier, pp.59-118, 2005, Foundations of artificial intelligence, 0-444-51493-7. ⟨hal-00922282⟩
371 Consultations
3351 Téléchargements
