Audio Declipping by Cosparse Hard Thresholding - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Document Associé À Des Manifestations Scientifiques Année : 2014
Recovery of clipped wideband audio signals is a very challenging inverse problem. Recently, it has been successfully addressed by several methods based on the sparse synthesis data model. In this work we propose an algorithm for enhancement of clipped wideband audio signals that exploits the sparse analysis (cosparse) data model. Experiments on real audio data indicate that the algorithm has better signal restoration performance than state-of-the-art sparse synthesis declipping methods.
CoDecHT.pdf (72.94 Ko) Télécharger le fichier
hal-00922497 , version 1 (27-12-2013)
hal-00922497 , version 2 (13-01-2014)
hal-00922497 , version 3 (01-03-2014)
  • HAL Id : hal-00922497 , version 2
Srđan Kitić, Nancy Bertin, Rémi Gribonval. Audio Declipping by Cosparse Hard Thresholding. . ⟨hal-00922497v2⟩
785 Consultations
580 Téléchargements
