An asymptotic two layers monodomain model of cardiac electrophysiology in the atria - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2014
Numerical simulations of the cardiac electrophysiology in the atria are often based on the standard bidomain or monodomain equations stated on a two-dimensional manifold. These simulations take advantage of the thinness of the atrial tissue, and their computational costs is reduce, as compared to three-dimensional simulations. However, these models do not take into account the heterogeneities located in the thickness of the tissue, like discontinuities of the fiber direction, although they can be a substrate for atrial arrhythmia [Hocini et al., 2002, Ho et al., 2002, Nattel, 2002]. We investigate a two-dimensional model with two coupled, superimposed layers that allows to introduce three-dimensional heterogeneities, but retains a reasonable computational cost. We introduce the mathematical derivation of this model, show its convergence toward the three-dimensional model and give some numerical illustration of its interest. Our model would be an efficient tool to test the influence of three-dimensional fiber direction heterogeneities in reentries or atrial arrhythmia without using three-dimensional models.
RR-8593.pdf (2.11 Mo) Télécharger le fichier
hal-00922717 , version 1 (30-12-2013)
hal-00922717 , version 2 (09-09-2014)
hal-00922717 , version 3 (11-10-2016)
hal-00922717 , version 4 (18-03-2017)
  • HAL Id : hal-00922717 , version 2
Yves Coudière, Jacques Henry, Simon Labarthe. An asymptotic two layers monodomain model of cardiac electrophysiology in the atria. [Research Report] RR-8593, INRIA. 2014, pp.32. ⟨hal-00922717v2⟩
Collections
INRIA-RRRT LARA
566 Consultations
526 Téléchargements
