Necessary and sufficient conditions for continuity of optimal transport maps on Riemannian manifolds - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Tohoku mathematical journal Année : 2011
Ludovic Rifford
Cédric Villani
  • Fonction : Auteur
  • PersonId : 834500
  • IdRef : 074309854
In this paper we investigate the regularity of optimal transport maps for the squared distance cost on Riemannian manifolds. First of all, we provide some general necessary and sufficient conditions for a Riemannian manifold to satisfy the so-called Transport Continuity Property. Then, we show that on surfaces these conditions coincide. Finally, we give some regularity results on transport maps in some specific cases, extending in particular the results on the flat torus and the real pro jective space to a more general class of manifolds.
FRV_REG_DEF.pdf (231.27 Ko) Télécharger le fichier
hal-00923320 , version 1 (02-01-2014)
Alessio Figalli, Ludovic Rifford, Cédric Villani. Necessary and sufficient conditions for continuity of optimal transport maps on Riemannian manifolds. Tohoku mathematical journal, 2011, 63 (4), pp.855-876. ⟨10.2748/tmj/1325886291⟩. ⟨hal-00923320⟩
688 Consultations
145 Téléchargements
