Result Certification of Static Program Analysers with Automated Theorem Provers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The automation of the deductive approach to program veri- fication crucially depends on the ability to efficiently infer and discharge program invariants. In an ideal world, user-provided invariants would be strengthened by incorporating the result of static analysers as untrusted annotations and discharged by automated theorem provers. However, the results of object-oriented analyses are heavily quantified and cannot be discharged, within reasonable time limits, by state-of-the-art auto- mated theorem provers. In the present work, we investigate an original approach for verifying automatically and efficiently the result of certain classes of object-oriented static analyses using off-the-shelf automated theorem provers. We propose to generate verification conditions that are generic enough to capture, not a single, but a family of analyses which encompasses Java bytecode verification and Fähndrich and Leino type- system for checking null pointers. For those analyses, we show how to generate tractable verification conditions that are still quantified but fall in a decidable logic fragment that is reducible to the Effectively Propositional logic. Our experiments confirm that such verification conditions are efficiently discharged by off-the-shelf automated theorem provers.
result_certification_of_static_program_analysers_with_automated_theorem_provers.pdf (299.85 Ko) Télécharger le fichier
hal-00924167 , version 1 (06-01-2014)
  • HAL Id : hal-00924167 , version 1
Frédéric Besson, Pierre-Emmanuel Cornilleau, Thomas Jensen. Result Certification of Static Program Analysers with Automated Theorem Provers. VSTTE 2013 - Fifth Working Conference on Verified Software: Theories, Tools and Experiments, 2013, Atherthon, United States. ⟨hal-00924167⟩
653 Consultations
110 Téléchargements
