Merging two tactile stimulation principles: electrovibration and squeeze film effect - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Electrovibration and squeeze film effect can modify the perception a user has of a flat surface. These two stimulation principles are compatible, which means that they can be used at the same time on the same tactile stimulator. This paper first highlights the differences between the two principles, then gives experimental results obtained when merging, with specific conditions, these two stimulation principles.
Fichier non déposé
hal-00924644 , version 1 (07-01-2014)
  • HAL Id : hal-00924644 , version 1
Frédéric Giraud, Betty Lemaire-Semail, Michel Amberg. Merging two tactile stimulation principles: electrovibration and squeeze film effect. World Haptics Conference (WHC), 2013, Apr 2013, Daejon, South Korea. ⟨hal-00924644⟩
215 Consultations
0 Téléchargements
