Universal Security; From bits and mips to pools, lakes - and beyond
The relation between cryptographic key lengths and security depends on the cryptosystem used. This leads to confusion and to insecure parameter choices. In this note a universal security measure is proposed that puts all cryptographic primitives on the same footing, thereby making it easier to get comparable security across the board.
Cryptographie et sécurité [cs.CR]
