Universal Security; From bits and mips to pools, lakes - and beyond - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The relation between cryptographic key lengths and security depends on the cryptosystem used. This leads to confusion and to insecure parameter choices. In this note a universal security measure is proposed that puts all cryptographic primitives on the same footing, thereby making it easier to get comparable security across the board.
635.pdf (82.36 Ko) Télécharger le fichier
hal-00925622 , version 1 (08-01-2014)
Arjen K. Lenstra, Thorsten Kleinjung, Emmanuel Thomé. Universal Security; From bits and mips to pools, lakes - and beyond. Number Theory and Cryptography, Nov 2013, Darmstadt, Germany. pp.121-124, ⟨10.1007/978-3-642-42001-6_9⟩. ⟨hal-00925622⟩
320 Consultations
846 Téléchargements
