Mean field games systems of first order - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Control, Optimisation and Calculus of Variations Année : 2015
We consider a system of mean field games with local coupling in the deterministic limit. Under general structure conditions on the Hamiltonian and coupling, we prove existence and uniqueness of the weak solution, characterizing this solution as the minimizer of some optimal control of Hamilton-Jacobi and continuity equations. We also prove that this solution converges in the long time average to the solution of the associated ergodic problem.
mean_field_games-20140108.pdf (379.4 Ko) Télécharger le fichier
hal-00925905 , version 1 (08-01-2014)
Pierre Cardaliaguet, Philip Jameson Graber. Mean field games systems of first order. ESAIM: Control, Optimisation and Calculus of Variations, 2015, 21 (3), pp.690-722. ⟨hal-00925905⟩
737 Consultations
399 Téléchargements
