On the packing chromatic number of hypercubes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Electronic Notes in Discrete Mathematics Année : 2013
The packing chromatic number $\chi_\rho(G)$ of a graph $G$ is the smallest integer $k$ needed to proper color the vertices of $G$ in such a way that the distance in $G$ between any two vertices having color $i$ be at least $i+1$. Goddard et al. \cite{Goddard08} found an upper bound for the packing chromatic number of hypercubes $Q_n$. Moreover, they compute $\chi_\rho(Q_n)$ for $n \leq 5$ leaving as an open problem the remaining cases. In this paper, we obtain a better upper bound for $\chi_\rho(Q_n)$ and we compute the exact value of $\chi_\rho(Q_n)$ for $6 \leq n \leq 8$.
torres-valencia-vfinal-sansformat.pdf (97.22 Ko) Télécharger le fichier
hal-00926875 , version 1 (10-01-2014)
  • HAL Id : hal-00926875 , version 1
Pablo Torres, Mario Valencia-Pabon. On the packing chromatic number of hypercubes. Electronic Notes in Discrete Mathematics, 2013, 44 (5), pp.263-268. ⟨hal-00926875⟩
229 Consultations
733 Téléchargements
