A constraint programming approach for managing end-to-end requirements in sensor network macroprogramming - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Though several high-level application development (macroprogramming) approaches have been proposed in literature for wireless sensor networks (WSN), there is a need to enable support for expressing and supporting end-to-end non-functional constraints such as latency in WSN macroprograms. We augment an existing macroprogramming language and its compilation process to enable the specification of end-to-end requirements, and propose task mapping algorithms to satisfy those requirements through a constraint programming approach. Through evaluations on realistic application task graphs, we show that our constraint programming model can effectively capture the end-to-end requirements and efficiently solves the combinatorial problem introduced.
Fichier non déposé
hal-00927148 , version 1 (11-01-2014)
  • HAL Id : hal-00927148 , version 1
Farshid Hassani Bijarbooneh, Animesh Pathak, Justin Pearson, Valérie Issarny, Bengt Jonsson. A constraint programming approach for managing end-to-end requirements in sensor network macroprogramming. SENSORNETS 2014 - 3rd International Conference on Sensor Networks, Jan 2014, Lisbon, Portugal. ⟨hal-00927148⟩
Collections
INRIA INRIA2
93 Consultations
0 Téléchargements
