A front tracking method for a strongly coupled PDE-ODE system with moving density constraints in traffic flow - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete and Continuous Dynamical Systems - Series S Année : 2014
In this paper we introduce a numerical method for tracking a bus trajectory on a road network. The mathematical model taken into consideration is a strongly coupled PDE-ODE system: the PDE is a scalar hyperbolic conservation law describing the traffic flow while the ODE, that describes the bus trajectory, needs to be intended in a Carathéodory sense. The moving constraint is given by an inequality on the flux which accounts for the bottleneck created by the bus on the road. The finite volume algorithm uses a locally non-uniform moving mesh which tracks the bus position. Some numerical tests are shown to describe the behavior of the solution.
TRAM2DelleMonacheGoatin.pdf (262.91 Ko) Télécharger le fichier
hal-00930031 , version 1 (24-01-2014)
  • HAL Id : hal-00930031 , version 1
Maria Laura Delle Monache, Paola Goatin. A front tracking method for a strongly coupled PDE-ODE system with moving density constraints in traffic flow. Discrete and Continuous Dynamical Systems - Series S, 2014, 7 (3), pp.435-447. ⟨hal-00930031⟩
780 Consultations
549 Téléchargements
