The OCaml system release 4.13: Documentation and user's manual - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2021
This manual documents the release 4.13 of the OCaml system. It is organized as follows. Part I, "An introduction to OCaml", gives an overview of the language. Part II, "The OCaml language", is the reference description of the language. Part III, "The OCaml tools", documents the compilers, toplevel system, and programming utilities. Part IV, "The OCaml library", describes the modules provided in the standard library. Part V, “Indexes”, contains an index of all identifiers defined in the standard library, and an index of keywords.
ocaml-4.13-refman.pdf (2.32 Mo) Télécharger le fichier
hal-00930213 , version 1 (14-01-2014)
hal-00930213 , version 2 (05-11-2014)
hal-00930213 , version 3 (09-12-2016)
hal-00930213 , version 4 (05-11-2017)
hal-00930213 , version 5 (25-08-2018)
hal-00930213 , version 6 (19-11-2019)
hal-00930213 , version 7 (09-12-2020)
hal-00930213 , version 8 (18-12-2021)
hal-00930213 , version 9 (20-12-2022)
hal-00930213 , version 10 (24-11-2023)
  • HAL Id : hal-00930213 , version 8
Xavier Leroy, Damien Doligez, Alain Frisch, Jacques Garrigue, Didier Rémy, et al.. The OCaml system release 4.13: Documentation and user's manual. [Intern report] Inria. 2021, pp.1-876. ⟨hal-00930213v8⟩
1429 Consultations
4385 Téléchargements
