Manifold reconstruction using tangential Delaunay complexes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete and Computational Geometry Année : 2014
Jean-Daniel Boissonnat
  • Fonction : Auteur
  • PersonId : 935453
We give a provably correct algorithm to reconstruct a k-dimensional smooth manifold embedded in d-dimensional Euclidean space. The input to our algorithm is a point sample coming from an unknown manifold. Our approach is based on two main ideas : the notion of tangential Delaunay complex and the technique of sliver removal by weighting the sample points. Differently from previous methods, we do not construct any subdivision of the d-dimensional ambient space. As a result, the running time of our al- gorithm depends only linearly on the extrinsic dimension d while it depends quadratically on the size of the input sample, and exponentially on the intrinsic dimension k. To the best of our knowledge, this is the first certified algorithm for manifold reconstruction whose complexity depends linearly on the ambient dimension. We also prove that for a dense enough sample the output of our algorithm is isotopic to the manifold and a close geometric approximation of the manifold.
Journal-version.pdf (641.19 Ko) Télécharger le fichier
Format : Figure, Image
hal-00932209 , version 1 (16-01-2014)
Jean-Daniel Boissonnat, Arijit Ghosh. Manifold reconstruction using tangential Delaunay complexes. Discrete and Computational Geometry, 2014, 51 (1), pp.221-267. ⟨10.1007/s00454-013-9557-2⟩. ⟨hal-00932209⟩
Collections
INRIA INRIA2 ANR
381 Consultations
699 Téléchargements
