Optimizing BRDF Orientations for the Manipulation of Anisotropic Highlights - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Graphics Forum Année : 2014
This paper introduces a system for the direct editing of highlights produced by anisotropic BRDFs, which we call anisotropic highlights. We first provide a comprehensive analysis of the link between the direction of anisotropy and the shape of highlight curves for arbitrary object surfaces. The gained insights provide the required ingredients to infer BRDF orientations from a prescribed highlight tangent field. This amounts to a non-linear optimization problem, which is solved at interactive framerates during manipulation. Taking inspiration from sculpting software, we provide tools that give the impression of manipulating highlight curves while actually modifying their tangents. Our solver produces desired highlight shapes for a host of lighting environments and anisotropic BRDFs.
main.pdf (2.03 Mo) Télécharger le fichier
hal-00933264 , version 1 (20-01-2014)
hal-00933264 , version 2 (20-01-2014)
  • HAL Id : hal-00933264 , version 1
Boris Raymond, Gaël Guennebaud, Pascal Barla, Romain Pacanowski, Xavier Granier. Optimizing BRDF Orientations for the Manipulation of Anisotropic Highlights. Computer Graphics Forum, 2014. ⟨hal-00933264v1⟩
1680 Consultations
1245 Téléchargements
