Comparator: A Tool for Quantifying Behavioural Compatibility
We present Comparator, a tool that measures the compatibility between two behavioural interfaces. Comparator can be used as a stand-alone Web application, and is also integrated into a model-based adaptation toolbox.
Génie logiciel [cs.SE]
