The oscillations killer: a mechanism to eliminate undesired limit cycles in a class of nonlinear systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Robust and Nonlinear Control Année : 2014
In this paper, we present a mechanism, called oscillation killer, intended to eliminate limit cycles that may occur as a consequence of unexpected external disturbances, interactions with the environment, changes in systems set-points, physical parameters, and so on. Examples range from controlled systems with friction to electrical networks with varying loads and impedances. The proposed mechanisms is shown to be particulary appropriate for nonlinear systems displaying a locally asymptotically equilibrium point surrounded by a locally asymptotically stable limit set outside this local domain.
hal-00934086 , version 1 (21-01-2014)
Carlos Canudas de Wit, Javier Aracil, Francisco Gordillo Álvarez, Francisco Salas. The oscillations killer: a mechanism to eliminate undesired limit cycles in a class of nonlinear systems. International Journal of Robust and Nonlinear Control, 2014, 24 (1), pp.39-53. ⟨10.1002/rnc.2873⟩. ⟨hal-00934086⟩
223 Consultations
0 Téléchargements
