Document Noise Removal using Sparse Representations over Learned Dictionary - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès The 13th ACM Symposium on Document Engineering (DocEng) Année : 2013
In this paper, we propose an algorithm for denoising document images using sparse representations. Following a training set, this algorithm is able to learn the main document characteristics and also, the kind of noise included into the documents. In this perspective, we propose to model the noise energy based on the normalized cross-correlation between pairs of noisy and non-noisy documents. Experimental results on several datasets demonstrate the robustness of our method compared with the state-of-the-art.
fp032-haPS.pdf (2.53 Mo) Télécharger le fichier
hal-00939174 , version 1 (13-02-2014)
Thanh Ha Do, Salvatore Tabbone, Oriol Ramos Terrades. Document Noise Removal using Sparse Representations over Learned Dictionary. The 13th ACM Symposium on Document Engineering, Sep 2013, Florence, Italy. ⟨10.1145/2494266.2494281⟩. ⟨hal-00939174⟩
105 Consultations
279 Téléchargements
