Decomposition theorem and Riesz basis for axisymmetric potentials in the right half-plane - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2014
The Weinstein equation with complex coefficients is the equation governing generalized axisymmetric potentials (GASP) which can be written as Lm[u]=∆u+(m/x)∂xu=0,where m∈C. We generalize results known for m ∈ R to m ∈ C. We give explicit expressions of fundamental solutions for Weinstein operators and their estimates near singularities, then we prove a Green's formula for GASP in the right half-plane H+ for Re m < 1. We establish a new decomposition theorem for the GASP in any annular domains for m ∈ C, which is in fact a generalization of the Bocher's decomposition theorem. In par- ticular, using bipolar coordinates, we prove for annuli that a family of solutions for GASP equation in terms of associated Legendre functions of first and second kind is complete. For m ∈ C, we show that this family is even a Riesz basis in some non-concentric circular annulus.
CR.pdf (396.12 Ko) Télécharger le fichier
hal-00940237 , version 1 (03-02-2014)
hal-00940237 , version 2 (08-03-2016)
Slah Chaabi, Stephane Rigat. Decomposition theorem and Riesz basis for axisymmetric potentials in the right half-plane. 2014. ⟨hal-00940237v1⟩
449 Consultations
163 Téléchargements
