Open Loop Optimistic Planning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We consider the problem of planning in a stochastic and discounted environment with a limited numerical budget. More precisely, we investigate strategies exploring the set of possible sequences of actions, so that, once all available numerical resources (e.g. CPU time, number of calls to a generative model) have been used, one returns a recommendation on the best possible immediate action to follow based on this exploration. The performance of a strategy is assessed in terms of its simple regret, that is the loss in performance resulting from choosing the recommended action instead of an optimal one. We first provide a minimax lower bound for this problem, and show that a uniform planning strategy matches this minimax rate (up to a logarithmic factor). Then we propose a UCB (Upper Confidence Bounds)-based planning algorithm, called OLOP (Open-Loop Optimistic Planning), which is also minimax optimal, and prove that it enjoys much faster rates when there is a small proportion of near-optimal sequences of actions. Finally, we compare our results with the regret bounds one can derive for our setting with bandits algorithms designed for an infinite number of arms.
COLT10_BM.pdf (218.34 Ko) Télécharger le fichier
hal-00943119 , version 1 (07-06-2021)
  • HAL Id : hal-00943119 , version 1
Sébastien Bubeck, Rémi Munos. Open Loop Optimistic Planning. COLT 2010 - The 23rd Conference on Learning Theory, Jun 2010, Haifa, Israel. ⟨hal-00943119⟩
197 Consultations
75 Téléchargements
